ascii404
Пользователь
НЕ ПРОВЕРЕН
НЕ ПРОВЕРЕН
A sure solution to RED WARNING SCAMPAGE
"Silent AI-Driven Defender for any Scampage "
by SafeHeavenTeam
No More Red Flags – Stay Invisible
Tired of your sites getting flagged or taken down by bots within minutes? You're not alone.
Many have faced the frustration of setting up new office365 and gmail or banks scampage, only to see it scanned, flagged, or shut down by automated systems almost instantly.
But what if you could bypass all of them - Google bots, Cloudflare scanners, security crawlers, takedown scripts - without relying on outdated tricks?
Just real protection
This advanced method filters out unwanted traffic silently and efficiently - without disrupting access for real users.
Core Features (Remotely Manage The Antibot.php Script)
![]() | Feature | Description |
![]() | Config Management (No DB) | All client settings done remotely from any smart phone devices or computer anywhere in the world |
![]() | Auto-apply updates | antibot.php fetches live config, updates in real-time |
![]() | Telegram + Email Alert Settings | Toggle on/off, set token, chat ID, alert email, etc |
![]() | Visit Limits & Session Duration | Define how often and how long visitors stay |
![]() | Allowed Countries & User-Agents | Fully editable from UI by clients themselves |
![]() | Test Config Button | Test direct if AntiBot/AntiRed is properly configured on the client Scampage |
![]() | Silent Login Options | Clients see only their settings and third-party can't notice any changes |
![]() | Realtime Status Indicators | Show if client protection is ON, OFF, or expired |
![]() | Auto Deploy via SFTP (Admin Only) | Securely push antibot.php to client websites |
![]() | Push Notifications | Receives Telegram/email alerts when any config is modified |
![]() | Usage Analytics | Show hits, blocks, bots detected, alerts sent (per client) to Telegram ID provided or Email |
![]() | Admin Disables Specific Features (Premium) | Turn off telegram alerts, logging, country blocks individually per client |
![]() | License Key + Expiry Check (Admin Only) | Control access via license system and expiry timer |
![]() | Client Login with Password | Client views & edits only their own settings securely |
![]() | Change Logs / Action Logs (Admin Only) | Show config edits, login records, errors |
![]() | Dark/Light Mode UI | Modern switch between beautiful light & dark themes |
How is The Script Powerful & Effective?
Blocks ALL Bots & Crawlers (Except Telegram Bot)
- Uses a list of known bots like Googlebot, Bingbot, and AhrefsBot.
- Detects stealth bots using advanced regex patterns (eg, Python requests, CURL, Wget).
- Ensures Telegram Bot is allowed while blocking all others.
IP Blacklisting & Third-Party Threat Intelligence
- Loads known malicious IPs from Spamhaus or other sources.
- Includes an option to manually block IPs & subnets (eg, 185.220.101.0/24).
- Prevents phishing services from flagging your website as “dangerous.”
Country-Based Access Control
- Only allows visitors from approved countries (eg, US, GB, DE, CA).
- Uses IP lookup API to verify the visitor's real country before granting access.
Cookie Fingerprinting – Detects Bots That Don't Use Cookies
- Bots don't store cookies like real browsers.
- If a visitor has no cookies , they're immediately blocked as a bot .
Visit & Session Tracking – Prevents Abuse
- Limits how many times a visitor can access the site.
- Restricts how long a visitor can stay on the site before getting blocked.
- Prevents bots from spamming your website with repeated access attempts.
Real-Time Security Alerts
- Sends instant alerts to Telegram & Email when a threat is detected.
- Logs every blocked bot, bad IP, and country block for forensic analysis .
Deep HTTP Header Analysis
- Checks for invalid or missing headers that indicate a bot.
- Blocks requests without proper User-Agent, Referer, or Cookie headers .
BotSentinel Client Panel – Secure. Smart. Effortless.
Protect your scampage with the next-level intelligence.
BotSentinel is a powerful, client-side security dashboard designed to give you full control
over suspicious visits, bot detection, and real-time alerts
– all through an intuitive, user-friendly panel.
Ensure that your scampage has antibots features and is undetectable.
Test its detectability on
.Download:
PM Me for access key and free script![]()
Закрыто на проверку!
Так же, прошу ознакомиться с правилами раздела - https://bdfclub.com/threads/pravila-razdela.154374/
- Статус
- В этой теме нельзя размещать новые ответы.
Поделиться:
